Ethos 0 Posted July 6, 2008 Hi guys, Thought I best torque up this, can't seem to find it in the haynes though. Anyone know what torque this is meant to be set to? Thanks. Share this post Link to post Share on other sites
dcc 855 Posted July 6, 2008 I would also be interested to know this, as i have only tighened mine as much as possible by hand Share this post Link to post Share on other sites
Ryan 99 Posted July 6, 2008 It's listed in the Hyanes manual as "Driveshaft intermediate bearing bracket" 17 lb.ft Share this post Link to post Share on other sites
Ethos 0 Posted July 6, 2008 Hmmm, I would have thought that would be the two 11mm for the drivers driveshaft? Share this post Link to post Share on other sites
Ryan 99 Posted July 6, 2008 Those are listed separately in the driveshafts chapter. Share this post Link to post Share on other sites
gti-si 0 Posted July 7, 2008 I just go by feel on things like this. As tight as you can should be fine unless your using a spanner with 2inch leverage...also assuming you ate your weetabix? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 7, 2008 They are listed in chapter 1 under engine mountings; RH nut; 27 Nm 20lbft. LH nut; 35NM 26lbft. Battery tray / Bracket; 18Nm 13lbft. Lower mounting centre bolt; 34Nm 25lbft. Lower motnting to subframe; 45Nm 33lbft. Graham. Share this post Link to post Share on other sites
