Batfink
[race_prep] 205 Gti St Build
Batfink
I'd rather have a lot of head clearance so getting as low as possible is certainly the way forward. I dont think bars gets me low enough and the extra inch will help. I'll have plenty of height control with the seat side mounts should a second driver be required...
Kev
Matt Holley
Kev
Ah I see you are bolting direct to the floor, no bars at all?
James_R
All the pictures have gone :ph34r:
Any updates Kev?
Batfink
no progress at the moment. Gearbox casing is waiting at a specialist to be done. Theres a long waiting list apparently.
Batfink
I've been buying a couple of bits. I now have three master cylinders for the pedal box (well only two have so far turned up)
I've been thinking about lowering the spec of the build to get this on the road so I plan to use a test engine, a near standard lump to get the car running and set up. A fancy engine can come after I have had some fun.
I've made a bid for a 1,8 engine so will see if I get it....it will need a custom inlet for throttlebodies, and hopefully the dry sump will fit.
I've asked Colin to get the gearbox done so I can get the car back for the winter.
Only major things Colin has to do is convert the touring car driveshafts to fit 205 hubs, build the gearbox with the right ratios, fit a seat to the floor and position the gearlever in the right place.
Sadly work will be very slow as I cannot focus much time to this but I want it working for next summer.
Just for you james i've added some old pictures. If you want any specifically then let me know :wacko:
Edited by Batfink
Noice!
What's the bracket/tube etc coming off the OS inner wing/chassis rail for?
Batfink
  Baz said:
Noice!
Thats the top engine mount :wacko: Bolts straight on the block
Batfink
I now have a 1.8 XU7JP4 engine sitting at colins :lol:
Of course it cannot remain standard so I will be upping the performance a bit
New parts I have to bolt on:
A gti6 head and exhaust manifold - thanks to Alastairh - I think with the limitations of the 1.8 head around the valves this will be the cheapest option to start, also I dont have to purchase an aftermarket exhaust manifold which I think would have limited benefit with the smaller capacity block
I will be purchasing a few other parts to get some power
Some 4903109 catcams are about the limit I can go with standard pistons. I wonder if Colin or sandy can say whether there is enough metal that the valve cutouts can be enlarged on standard pistons...might be a budget option to get better camshafts in place though probably will just leave them a weak point in the build.
Cameron is bringing round some blanking plates tomorrow too :P
Rest of the spec will be as planned.
Dry Sump
Throttlebodies - will see if my touring car inlet manifold fits this head though I suspect not
Lightweight pulleys
Small alternator
8 injectors
Touring car flywheel and twin plate clutch
I'll still be trying to reduce the parasitic losses as much as possible. Now if I can get 180 bhp out of this engine I think I should be happy.
Colin has hopefully prompted the gearbox guy to finish the casing, though we have a spare we can whack a diff in to get all the driveshafts fitted. Colin will convert all the touring car driveshafts I have so I have a set spare.
Edited by Batfink
j_turnell
Looking good, interested to see how the engine progresses.
Sandy
Those cams may fit as is, but we can check at some point.
Batfink
the 109's will be ok, just if I want to go more lairy the valves will hit the pistons
Cameron
Woo I got a mention! :(
Looks awesome though, makes me want a respray.
DrSarty
Don't forget the GTI6 OE cams and pulleys are mine dude. Either whip 'em out at yours or leave them in to go down to Colins and I can get them from there.
Looking good matey, and about time you stopped mincing. :D
