cyman
Water Direction Mi16
cyman
this maybe a silly question but i need it answerd.
in which direction does the water flow from the pump.
i think it goes from the pump to the rad then to the thermo housing then back around.
Pugnut
the other way dood.
from the pump out to the back of the block.
the easiest way to sus it out is the fact that hot water rises so the outlet of a rad will always be at the bottom where the water is coolest.
