Peetypug
Oil Pressure Problem
Peetypug
started my 205 yesterday, then noticed it was blowing bubbles of oil out of the filler cap.
I can only think of 3 reasons for this
1, blocked breather pipe
2, head gasket gone
3, gases getting past the piston rings.
I know i can do a compression test to see if its the piston rings, but how can i check the other 2?
johnnyboy666
1. take it off and poke summit through to unblock it
3. check oil to see if its got water in it, and check water for oil, or go to the garage and they should be able todo a gas test thing for you for quite cheap
James_R
Try putting the cap on 180 deg round, they do it if the rubber doesn't seal properly on the top. seen it a couple of times.
Peetypug
i hope its that simple!
please let it be that simple, i miss driving 205s :(
jim205GTI
Poke something through? :( couldn't imagine that would do anygood if you were to rough with it as the oil goes through the top of the engine and past the cam......
Just had a look myself as i toppped my oil up :lol:
Fingers crossed for the simple!!!
johnnyboy666
Poke something through? :lol: couldn't imagine that would do anygood if you were to rough with it as the oil goes through the top of the engine and past the cam......
sorry my bad, was thinking of tu engine :(
Peetypug
right a quick update :)
everything is not good
came back up today and started the car
all seemed fine
then small bubbles from filler cap
i was a little bit annoyed
i pulled the dipstick out while it was running and pop loads of pressure and oil everywhere :lol:
so any ideas?
i know i shouldn't have pulled the dipstick out but cant believe its meant to have that much pressure behind it!
Peetypug
right, just had another look
turns out one of the breathers should of had a T piece in but didn't
its the pipe on the left from the rocker cover to the throttle body and air filter hoses
it wasn't vented so was building up back pressure and blowing it out
just hope it hasn't done and damage to any of the oil seals!
its now purring like a cat :)
gti-si
Which one is that Pete? the 6 or the XSi?
Edit: Just re-read the title, dosey tits
Edited by gti-si
Peetypug
here's some pics of the offending problem
the braided hose in the middle was straight to the throttle body
like this
and that solved the pressure problem
i then left it ticking over to charge the battery after adding a 12v supply to the alternator
went for a brew and when i came back there was smoke coming from the grill below the windscreen :P
so the battery was whipped off quick as possible!
and now i've had enough so i'm stripping it!!!
Edited by sorrentopete
gti-si
Any ideas what was smoking/burning?
Peetypug
i dont know :P
i got pissed off with it and went home!!!!!!
i'm not even going to bother looking
loads of bits for sale soon!!!!!
including the brand new coilovers
taylorspug
Were the wipers on by chance? If the motor has seized that would smoke if the wipers were left on, although usually it just melts the switch.
Peetypug
they were on earlier but i cant remember turning them off. They were very very slow though. But what makes me think it wasn't the wipers is that the smoke was coming out of the right side of the grill as you look at the car Directly above the heater matrix
