Tommer 0 Posted June 30, 2008 Hi all, Is there a way of resetting the central locking? Mine worked (sort of ) before, but then I fitted new lock barrels and the car has been stood since. now that I have connected the battery again, there is no central locking at all, I can lock the doors individuallly but there is no resistance or motor at all, I am unable to lock the boot too. could it be a fuse or a relay or is there some way of completely resetting it so that it will work again? cheers in advance. tommer Share this post Link to post Share on other sites
pug_ham 244 3 Cars Posted July 3, 2008 I don't think the c/l system has any of reset but there is a fuse (#7 20 or 25 amp) alog with a relay on the fusebox. (one of the l/h green ones on the fusebox iirc). The bootlock can be super stiff or immovable if the c/l motor has seized. Pop the cover off the boot & remove the motor to see if you can unlockthe boot now. Have you got the right key or have some of the locks been changed before you got the car? Graham. Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted July 3, 2008 you should still be able to lock the boot manually, takes quite a bit of force tho Share this post Link to post Share on other sites
Tommer 0 Posted July 4, 2008 cheers guys, checked the fuse and relay no joy all look good. all the locks work, the boot is just unlockable due the central locking being stuck... grr guess ill have to take the doors apart again cheers for info, Share this post Link to post Share on other sites
