foreigner
Xs To Gti
foreigner
Just planning my next failed project.
I got XS and want to do gti subframe and suspension swap.
Any problems there at all?
it's G reg.
Any suggestions appreciated.
Jrod
Need to cut the gearpost off the TU subframe and weldt it onto the GTI one.
Not worth it imo and I've had it.
Edited by Jrod
foreigner
Sorry forgot to mention that I am installing my trustworthy 1.9td with gearbox and gearstick and and all the bits from gti.
Just needed to know if subframe and suspension is straight swapp.
Batfink
no you need two solid subframe bushes from a 309.
352339 is the part number from peugeot and you need two of them ;)
Edited by Batfink
swordfish210
no you dont. You just need to cut the gear post off as Jrod says.
Jrod
If your putting a TD in then it will all just bolt on.
