smighall
Reshelling My Trackcar
smighall
I'm looking for a new shell to redo my trackcar. It's currently running a GTI6 engine, so which 205 models can i use where i won't have to arse about with engine mounts?
Do the lower models just need a gti subframe for the engine to drop in etc?
Sean
cybernck
earlier TU-engined 205's have a different top mount, but later ones have the GTI-style one.
also, diesels are XU-engined to begin with ;).
Remember than non GTI models will need surgery (hacking) to the rear wheelarches to run 15" wheels at a low ride height.
Personally when I reshelled my trackcar I bought a mechanically tired 1600 GTI non sunroof for £300. I'd keep your eye out for a GTI shell.
taylorspug
Worth considering a Gentry, ive seen a few about recently cheap as chips and looking in good condition. Obviously they have the GTI arches etc. And if you're lucky you may pick one up with full trevor, which you can sell on to recoup a few quid.
steve@cornwall
I have a stripped GTi sunny shell I want shot of !
smighall
That's my ideal, i had found one but the seller seems to have vanished now. I'm just after a 3 door non sunroof, i'm hoping to find a gti for the right money but just keeping my options open at the moment.
Bear in mind that by selling off all the unwanted stuff there is a couple of hundred quid to be had back, from memory I managed to sell the engine, gearbox, driveshafts, ECU, AFM, K&N kit, rear beam, exhaust system and wheels off the one I bought.
DanteICE
I too have a very good condition shell that I want rid of, its white, no serious rust, unfortunately its a sunroof model, but you can just weld a non-sunroof roof off any other 205 on. Can sell with 1.9 8v Engine too, and interior if wanted?
Batfink
I'll chip in as well. My brother has a bare white rallye shell with turrets welded in the rear (had rear beam with a rear coilover conversion). Its a sunroof shell but on the plus side has polycarbonate windows fitted.
Bolt in your mechanicals and go....
He'll take £50 for it as thats what someones offered for it as scrap..
Its in St.albans (just off m25 junc 21a)
