S13Nick
Xu10 8v Turbo Water Pipe Kits
S13Nick
any 205 8v coolant pipe kits like the bbm one for example fit the XU10j2te engine?, as im not 100% cheers
or does anyone do a specific coolant pipe kit
Edited by S13Nick
sonofsam
Nothing specific for the 2.0L turbo no,
I can tell you wich BBM ones I used though :D I did have to get a little creative with some of though :D
S13Nick
any information appreciated... thanks
sonofsam
These are the BBM hoses I used:
Mi16 lower heater matrix pipe- fits with no mods
8V top readiator hose- Will need cutting and T-piece inserting, if you are using the OE 2.0L turbo heat exchanger**?
You will also need another connection into the top hose for the turbo return water supply, wich also needs a connection of to the expansion tank top right hose
(wich is not BBM as it got so short it wasnt worth buying one).
8V lower expansion tank pipe- a little tight to route around the back of the turbo to the water distrubution block.
** heat exchanger also needs a connection to the bottom radiator hose, I welded a union on the metal pipe for that.
You will also be able to use BBM top left expansion tank hose, I didn't as I had a Samco for that already.
On mine I also used a unequal plastic T-piece coming of the lower expansion tank pipe to go of the other side of the heater matrix wich I just used
a 205 rubber hose for.
Contact Stew directly and you can get a discount from being on the Forum.
Still need to draw a diagram for my last topic on this, if i get time in the week I will!
sonofsam
S13Nick
thanks alot!
they should sell a kit!
S13Nick
to be honest... samco looks better so what is the difference in price?
