S13Nick 0 Posted June 28, 2008 (edited) any 205 8v coolant pipe kits like the bbm one for example fit the XU10j2te engine?, as im not 100% cheers or does anyone do a specific coolant pipe kit Edited June 28, 2008 by S13Nick Share this post Link to post Share on other sites
sonofsam 5 Posted June 28, 2008 Nothing specific for the 2.0L turbo no, I can tell you wich BBM ones I used though I did have to get a little creative with some of though Share this post Link to post Share on other sites
S13Nick 0 Posted June 28, 2008 any information appreciated... thanks Share this post Link to post Share on other sites
sonofsam 5 Posted June 28, 2008 These are the BBM hoses I used: Mi16 lower heater matrix pipe- fits with no mods 8V top readiator hose- Will need cutting and T-piece inserting, if you are using the OE 2.0L turbo heat exchanger**? You will also need another connection into the top hose for the turbo return water supply, wich also needs a connection of to the expansion tank top right hose (wich is not BBM as it got so short it wasnt worth buying one). 8V lower expansion tank pipe- a little tight to route around the back of the turbo to the water distrubution block. ** heat exchanger also needs a connection to the bottom radiator hose, I welded a union on the metal pipe for that. You will also be able to use BBM top left expansion tank hose, I didn't as I had a Samco for that already. On mine I also used a unequal plastic T-piece coming of the lower expansion tank pipe to go of the other side of the heater matrix wich I just used a 205 rubber hose for. Contact Stew directly and you can get a discount from being on the Forum. Still need to draw a diagram for my last topic on this, if i get time in the week I will! Share this post Link to post Share on other sites
S13Nick 0 Posted June 29, 2008 thanks alot! they should sell a kit! Share this post Link to post Share on other sites
S13Nick 0 Posted June 29, 2008 to be honest... samco looks better so what is the difference in price? Share this post Link to post Share on other sites
