rapidmi
Suspension Setup For Trackcar
rapidmi
looking for new suspension for my track car, what shocks/ springs do yous use, anti roll bars etc?
ive got koni adjustables just now, still a bit of roll from the car just looking to get the handling properly sorted out.
smighall
Pugsport bilstein front coilovers with 300lb or 350lb springs, no front ARB, Eccentric top mounts and rosejointed wishbones running -3 degrees camber
Bilstein grp-n tarmac rear shocks with 23mm Torsion bars and 25mm ARB, ZX arms (soon to be turreted hopefully)
mmt
I run 309 front and rear suspension. 336 kg/inc front springs. 3 deg. neg. camper front and rear. 0 toe.
The car is on yokohama slicks.
Perfect!
/Martin
projectpug
GAZ shocks unknown red springs :D
Upper and lower strut braces
R888's
Works a treat if you want a budget setup
James_R
Gaz "golds" fronts 300lbs spring
25mm Rear bars (19,22,24,30mm ARB's)
Grp A beam mounts
ZX arms (soon to be -2.5deg camber arms)
Bilstien challange rear dampers
Guest RonnyJ
Spax coilovers in front with 325lbs springs i think, eccentric topmounts, rosejoint wishbones. ET 13mm.
309 rear suspension with 25mm torsionbars with öhlins dampers in the rear and we used spacers to get ET down to 5mm.
Our first and only setup we have got to try was -3 camber, 3mm toe out and as much caster as we could get.
Tires are 205/50/15 BFG R1. 2.2 bars on front and 2 bars on rear, cold pressures of course...
Didnt get to many laps on this setup and dont have any other setups to compare it with since it was my first time driving the car, but seemd to be handling well.
White Mi16: Koni's, Eibach springs, 309 bones, shafts & front ARB, 309 rear beam, 24mm ARB, Bilstein tarmac rear dampers. Lowered slightly not excessively.
Blue 1.6 std production class sprint car: Full Standard 1.6 setup, front OE dampers, Rear GTi6 dampers - And i feckin love it, absolutely brilliant for fast road/short sprint circuits.
White 1.9: Koni's all round, otherwise std, but quite low. Handles well, but i personally don't like it, bump steers and skips around too much, not enough suspension travel, although was fairly good on track.
Edited by Baz
