Para 82 2 Cars Posted June 28, 2008 Hi guys. I have dyno run booked at 12 of July, that's my first time. Any advices how to prepare the car and stuff ? Share this post Link to post Share on other sites
jord294 89 Posted June 28, 2008 (edited) make sure all fluids are at correct levels, and tyre pressures are correct. has the cambelt been done recently? Edited June 28, 2008 by jord294 Share this post Link to post Share on other sites
miamistu 1 Posted June 28, 2008 Scroll down to the bottom Share this post Link to post Share on other sites
Para 82 2 Cars Posted June 28, 2008 Thanks, My rev counter doesn't work. This will be a problem ? Share this post Link to post Share on other sites
Baz 421 Posted June 28, 2008 No, the dyno will be able to take a more accurate reading of revs anyway. Share this post Link to post Share on other sites
hengti 2 Posted June 28, 2008 to avoid the tuner having to spend his time doing it (and passing the cost onto you), i'd renew the plugs and make sure things like the distributor cap and rotor arm (etc) are also OK. checking that there are no problems with the oil breather circuit is a good idea too; something like a dipstick with a broken seal can affect your idle and the tuner might want to replace it if it's causing a problem - just little things like that really. Share this post Link to post Share on other sites
Para 82 2 Cars Posted July 14, 2008 Here are my results. What do you think about the drop of power at 5500rpm ?? What do you think about the results ?? Torque is only a quess http://www.youtube.com/watch?v=4y9YfVRtoN8 Share this post Link to post Share on other sites
welshpug 1,636 Posted July 14, 2008 looks pretty good and healthy for a 2.0 Mi16, exactly the same as my engine. book power is 155bhp but mine has also run 161bhp a few times, torque is healthy too. Share this post Link to post Share on other sites
Para 82 2 Cars Posted July 14, 2008 Sorry for pictures. It didn't worked for the first time. Share this post Link to post Share on other sites
