BossHogg
A Clunk And Very Annoying Clunk
BossHogg
Ok i have a pet clunk it's loud and comes from the front left of my car. I have changed the top mounts for both struts and still is clunks. It's not the brakes as i swapped the 1.6 calipers for 1.9 calipers and isn't dependent on brake useage.
The only things i can think of now to change are the wishbone bushes or possibly the gearbox mount as i have changed all the rest of the engine mounts apart from the gearbox.
Anybody else have any ideas?
hengti
have you disconnected the balljoint pin from the carrier to check it?
GTI6BOY
droplink?
BossHogg
No i haven't i'll give that a try in the morning
Its worth re torquing all the subframe bolts.
allanallen
would this be a clunk when applying brakes when reversing? my mums cti does it and i couldn't way up what it was :angry:
BossHogg
no it happens over bumps, cornering hard, even just for the hell of it :ph34r:
GTI6BOY
DROPLINKS?
Edited by GTI6BOY
hengti
droplink or bottom arm balljoint are the most likely candidates ime
steve@cornwall
DROPLINKS?
Would think so, too. Put a lever between the bottom of the wishbone, over the ARB next to the bottom joint of the droplink and lever down - the joint on the link should not separate at all.
BossHogg
Sounds like a good plan, i'll give that a try also in the morning,
ta chaps
GTI6BOY
take the left link off and go over a speed bump then you will know
bobob
DROPLINKS?
Who said that? :ph34r::angry:
BossHogg
Well nipped everything up. Made sure i had got the springs in their holders properly, checked the drop links, and now the clunk has gone. It'll probably reappear at some point just to annoy me.
But thanks everyone for your ideas. ;)
GTI6BOY
Who said that?
Whats the problem ;)
Its always that or the ball joint when it clunks
bobob
Sorry, it's just that I found it funny that you said it first time and everyone ignored you :blink: must be my crap sense of humor :lol::)
Edited by bobob
GTI6BOY
yeah sorry... just wondered why everyone skipped past my comment especially when its 99% the problem
BossHogg
A quick bit of recap, the problem turned out to be the gearbox mount, all the nuts were loose hence the clunking. So i took the opportunity to whap on a Grp N mount and all has been sorted.
Thanks for the help and suggestions guys
