dazEmad 0 Posted June 27, 2008 Can anyone confirm if the stud pattern on the 2.0mi head is the same as the 1.9mi head and if bottom or top row are the same. Looking at the gti6 exhaust manifold mating to an existing 1.9mi the bottom row is the same but the top is different. So what we are trying to achieve whilst this head 1.9mi is available for testing is to weld a flange and angle it, Only problem is its going to be used on my 2.0mi. Share this post Link to post Share on other sites
jackherer 543 Posted June 27, 2008 2.0 Mi have ten studs, the top row mirrors the bottom five. Share this post Link to post Share on other sites
returnofjim 0 Posted July 3, 2008 2.0 Mi have ten studs, the top row mirrors the bottom five. Thats good news then, so the 2.0 mi head must have the same stud pattern as a gti6? Share this post Link to post Share on other sites
Anthony 1,003 Posted July 3, 2008 Thats good news then, so the 2.0 mi head must have the same stud pattern as a gti6? Sadly not, no. Share this post Link to post Share on other sites
mrswampy 0 Posted July 3, 2008 no the s16 is different buy only one of the studs is!! and you need to remove a part of the webbing on the gti6 manifold to get it to sit flush against the head Share this post Link to post Share on other sites
returnofjim 0 Posted July 3, 2008 no the s16 is differentbuy only one of the studs is!! and you need to remove a part of the webbing on the gti6 manifold to get it to sit flush against the head So only one of the studs on a s16/2.0mi is in a different place from the gti6 head? i guessed that some of the flange would have to be cut off, when i offered up the gti6 manifold to a 1.9 mi head the bottom row of studs was the same but all the top row was different and a large piece of the flange fouled the head. So if there is only 1 stud different then it should be quite easy to modify the flange on the gti6 manifold to get it to fit? which stud is it that is in a different place? Share this post Link to post Share on other sites
welshpug 1,670 Posted July 3, 2008 one problem is that the ports do not match the gti6 manifold. Share this post Link to post Share on other sites
returnofjim 0 Posted July 3, 2008 one problem is that the ports do not match the gti6 manifold. Yeh i had already realised this, im thinking maybe i can open out the sides of the ports on the flange of the manifold and taper it down to the pipes if you get what i mean. Share this post Link to post Share on other sites
SPGTi 2 Posted July 3, 2008 Maybe this will help FRom PeterT's website Steve Share this post Link to post Share on other sites
