JayCC
Cambelt/timing Belt
JayCC
Hi,
My mate needs to change his timing belt, tensioners, and waterpump (anything else?) and is unsure which one's he needs.
I had a look on GSF and their a few different ones.
He has a 1992 (J) 1.6 Gti, non CAT engine, so i assume its the 113 teeth belt?
Does anyone know the correct part numbers
James
JayCC
bump
Edited by JayCC
All the 1.6's use the 113 tooth belt
JayCC
Cheers Miles, will go to GSF monday morning :angry:
JayCC
They don't seem to list the tensioner part on the website, is it the same part as the 1.9?
N13166 TIMING BELT TENSIONER-SKF 205 1.9 GTi 24.50
also is this the water pump he needs?
N17006 WATER PUMP 205 1.6/1.9GTi ALL,17D >10/86 19.50
