damo 17 2 Cars Posted June 25, 2008 I was wondering if anyone could give me some pointers on the PAS installation? Working from the top of the engine - The front pipe thats metal and runs from the pump, I assume this goes under the manifold right? and the bracked screws into the battery stand? it just pipes seem to be in the way so it keeps catching the throttle switch. It is also sitting onto of the started notor under the inlet manifold? I then assume the plastic bit of pip goes over the gear box and round to the rack. Any way, I have a K&N filter so what would be the best place to sit the PAS fluid bottle? I was thinking to the left of the altenator on the wing? I hope this all makes sense? Damo. Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted June 25, 2008 I personally fitted the pipe with the inlet on but it is bit of a pain in the arse. I mounted my bottle along side the battery as i also had a k&N style filter so there was some room there, also can mount brackets to the battery tray. Share this post Link to post Share on other sites
