feb
Squeak When Clutch Pedal Is Pressed
feb
Hi,
When the clutch pedal is pressed there is a very small squeak noise (sounds more like a bird noise). You really have to struggle to hear it (only happens when I start the car from cold and for a short while, above 30km/h you can't hear it because it is masked by road/engine noise. I haven't heard it when the car is warm.
What could this be? Is it the release bearing of the clutch? Should I worry about it or not? I am going to the Ring in August and don't fancy being without a clutch suddenly.
The car is a 2007 WRX with 21k km.
Cheers :lol:
AdamP
Does sound like the thrust bearing to me. Could just be a little noisy or could be on its way out, that's the problem with bearings, you really can't tell.
