mad_dome 1 Posted June 25, 2008 hi everyone i was wondering how u turned up the boost useing a bleed valve on the 406 sri turbo engine????? can anyone help???? i need to no what hoses it goes into?????? cheers Share this post Link to post Share on other sites
Discostu 6 Posted June 26, 2008 hi everyone i was wondering how u turned up the boost useing a bleed valve on the 406 sri turbo engine????? can anyone help???? i need to no what hoses it goes into?????? cheers Dont use a bleed valve, use a 2 way manual boost controller. All you do is replace the electronic boost controller, although you will still need to leave it plugged into the wiring loom. Remember the standard ecu will only work upto 1bar of boost Share this post Link to post Share on other sites
