matty_gti 20 Posted June 25, 2008 Hi, just a quick q, will the seats out of a 205 gti inc subframes be a straight swap into a 205 van?. Matt Share this post Link to post Share on other sites
Anthony 1,003 Posted June 25, 2008 They are, but why would you want to use GTi subframes when there's no rear seats to need the tilt part of the subframe? You'd be better off using the van (or any 5dr) subframe as you'll sit a little lower and they'll be less play/slop. Share this post Link to post Share on other sites
McDude 33 Posted June 25, 2008 Or removing the tilt bit of the mechanism if you don't have any 5 door rails. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted June 25, 2008 Or removing the tilt bit of the mechanism if you don't have any 5 door rails. Except that you also loose the stock seatbelt if you try this, hence the general use of 5 door rails. Share this post Link to post Share on other sites
