paul_portsmouth
Wierd Idle
paul_portsmouth
it goes up and down when sat at lights
then next set sits on 900 perfect
next one at 1500
then up and down 400 - 1200
then 900
any ideas????
TRYNKEEPUP
I had this problem on my 1.9 gti, the problem in question is the air flow meter, i have eliminated this by fitting twin 45s now, its a common problem with gtis, all i can suggest is trying another afm if you have a spare, or borrow one, this may not cure it as its just a gti thing, but may help. i learnt to play throttle pedal to control mine takes bit of pratice but easy when you know how, hope this helps.
GLPoomobile
Yes it could be AFM related. My Mi started doing this once in traffic - as soon as I dipped the clutch and came off the throttle, the revs would dip to 800, bounce up to 1200, dip to 800, bounce to 1200, etc etc, until it would eventually dip a bit too low and stall. Trying to control it with the throttle was nigh on impossible, unless you held the revs at 1500 rpm+. This was the initial problem of a dead AFM, as the next time I used the car it wouldn't run, and it turned out the flap was stuck open, and when I released it and cleaned it all up inside the flap then had far too little tension, so it still wouldn't work properly.
But, another cause (common on Mis apparently) is wear in the throttle body, allowing air past the butterfly.
JimLad
Sometimes a hunting idle is caused by an air leak. Use a can of easy start around the inlet system to see if the idle increases. If it does you've found the leak.
McDude
TADTS (They All Do That Sir) - a common phrase heard by Lotus owners but applies perfectly to 205s
Guest 205bandit
Yes they all do it! it will probally never be perfect, serious cases are usually the AFM like said.
NOT TRUE!
I have made countless 205 GTIs idle perfectly.
