Para 82 2 Cars Posted June 24, 2008 Sorry if this question appear before. I just bought second cooling fan as I had only one in my GTI. How difficult it will be to connect it and does 1.6 GTI which have place for 2 fans but have only one is prepared to connect another one ?? There will be plug somewhere which will allow me to connect ? ps. I have 2.0 XU10J4 under the bonnet and one fan which is turning on by button. thanks in advance Mike Share this post Link to post Share on other sites
GTI6BOY 29 Posted June 24, 2008 They only come with 1...what do you want another for? If you water is to hot then you must have a problem. Im running 200bhp with only 1 fan Share this post Link to post Share on other sites
damien 22 1 Cars Posted June 24, 2008 you could wire the 2nd fan on its on switch Share this post Link to post Share on other sites
Para 82 2 Cars Posted June 24, 2008 I will prefer to have better cooling than only one fan, just in case. I would like to have the second one working with temperature sensor, and the old one as it is on the button. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 24, 2008 Another fan doesn't give better cooling!! The fans only run when the fan switch reaches the temp to turn them on so it will just cool it back to the temperature to switch the fans off quicker with two fitted. If your current fan works using a switch is it connected to the fan switch on the radiator in anyway? If not then you might simply be able to fit the cooling fan loom in & run one from the rad fan switch along with your manual controlled one. Graham. Share this post Link to post Share on other sites
Para 82 2 Cars Posted June 25, 2008 I've just found this topic and it will help me: http://forum.205gtidrivers.com/index.php?showtopic=20402 Share this post Link to post Share on other sites
