cyman
Headgasket Type And Thickness 1.5mm
cyman
Does anyone know what the part number is for a standard mi16 D6C 1.5mm.
pug dealers seamed a little confused with the issue. :wacko:
also, what are the thoughts on spesso and comitec head gaskets.
from servicebox;
0209 L3 CYL HEAD GASKET REPAR EP 1,50 (same gasket listed for the 1.6 1.8 and 1.9 8v)
0209 N2 REPAR(+0,2)
Edited by welshpug
cyman
thanks welshpug.
do you also have data on head bolts ?
yeah its all on servicebox, bolts are listed separately not as a kit;
0204 57 10 CYL HEAD BOLT M11X1.50-175mm
and the spacer
0205 28 10 SCREW SPACER DIAM 12,05 X 22 - 20
I'd just use Bolt set and a Head Gasket set from GSF, I've not had any problems with the parts they supply, though none have been on a modified engine.
N11412 CYLINDER HEAD GASKET SET BX 16 VALVE/405 1.9 Mi16 - INC HEAD GSKT £63.50
unsure what they list the headbolt set as.
Bally
I have used cometic with great results.
