dirtdog
Race/comp Mounts
dirtdog
i've seen upper lower and gearbox mounts which claim to be for comp' use. i was thinking about getting some fitted as there is LOADS of movement when it's revved up...and yes ok..its a agricultural engine(STDT) and its not being raced...obviously, but hopefully everyone appreciates the fact that i just like the feeling of a well oil machine(no pun intended) , nice and solid like
just wondering if they would fit, seeing as its not a gti? its a xu series but..are ALL the mounts the same regardless?
tom_m
yup straight swap. just bear in mind stiffer mounts transfer more engine and transmission vibrations to the chassis.
they do however make the front end feel much more together, so if you can live with the vibrations its a job thats well worth doing <_<
Edited by tom_m
