john-melbourne
Bouncing Rev Counter
john-melbourne
Hi Guys,
My mate has been trying to get my rev counter working today, he has finally got it moving but it will bounce when revved but then dies? Anyone else had this trouble or can offer a suggestion?
John
dirtdog
it bounces when revd? mine bounces on its own. lol. it looks like im tapping the throttle when its idling sometimes. other times it refuses to work at all. and sometimes it works just fine... i have no idea but it would be nice to know <_<
Para
Hi Guys,
John
I have exactly the same problem
DamirGTI
If the tachometer needle drops or bounces the faulty may be the primary ignition :wacko: check all the wirings and connectors on the ignition system particularly on the coil and the ignition amp. ...
Rgs ! :lol:
Damir
Edited by DamirGTI
gerlewislewis
whilst on the topic of bouncy guages, my speedo bounces a little, is this just due to a loose connection/missing split pin? or something more sinister.... :blink:
sonofsam
It's part of the 205 charm, or shall we call that - speedo cable routed over exhaust manifold, so it cooks all it's lube prematurely.
richard
I have something similar that occurs around the 4.5k rpm mark upwards, it will jump around a bit after this when taking it to around 6k,
doesnt do it if im smooth and gently take it to that level, but if i am to snatch a gear and hoof it thats when it happens.
Only thing i can think of thats changed on my car is the ignition amp. Maybe you have a damaged or dirty connection there?
