Jrod 7 Posted June 19, 2008 (edited) Just had a 4 wheel alignment done after I fitted my quick rack and 309 TCAs. Front: ...... L ........ R Camber. -0°35' -0°47' Caster ... 2°24' 1°53' Rear: ...... L ........ R Camber .-0°36' -0°49' Toe ........ 0°14' -0°04' Firstly, what could cause having less camer and more caster on the front? and is the rear enough to worry about as if it is I can change the stub axle? Edited June 19, 2008 by Jrod Share this post Link to post Share on other sites
welshpug 1,657 Posted June 19, 2008 front top mount may not be mounted the same, there is a bit of play in the std top mount drilling usually so you could just loosen the 3 bolts and move it. Share this post Link to post Share on other sites
