Bonzai 2 Posted June 16, 2008 In preparation for removing my old bumper and fitting a better looking (unbroken) one, what new bits should i buy? http://www.stuartmcguire.co.uk/pug/GB/205N/7/74A10A.HTM many thanks Share this post Link to post Share on other sites
gerlewislewis 0 Posted June 16, 2008 C, A, 9 you will probably snap Cs, and the 9s You can buy a load of Cs and 4s from a local screw shop for a few pence. Grab a few As aswell. The only bit you should really need from pug is a few 9s (if they snap), but even then you can buy bolts which match from a local screw shop - then grind the heads down a bit to allow clearance for the red insert (but id buy some 9s if I were you - or 11s? your diagram is a bit confusing) Ger Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted June 16, 2008 From experience the side mounts are also usually rusted into oblivion. I'd buy 4x 9 (bumper bolts) 2x 8 2x 7 half a dozen 11 (moulding clips) A are M8 nuts, and C are M8x20 bolts, both easily available from a bolt shop, and probably for less than Peugeot main dealer prices. Share this post Link to post Share on other sites
Bonzai 2 Posted June 17, 2008 thanks guys, i think, having looked at both my old and "new" bumpers ill order everything, depending on cost and availability, because all four examples are rusted to buggery and dont look like shifting easily Share this post Link to post Share on other sites
welshpug 1,666 Posted June 17, 2008 pop to DFMC on colchester avenue Ben, they're still a Peugeot parts and bodyshop even though it says alfa romeo on the front!! they may well have some of the bits you need from when I ordered some a while ago and they came in a big bag, I only wanted 2 Share this post Link to post Share on other sites
shooter mcgavin 37 Posted June 17, 2008 watch out for steelers prices i paid £32 for 2 side mount kits and a had full of nuts and bolts Share this post Link to post Share on other sites
Bonzai 2 Posted June 23, 2008 this is what ive ordered :- C - 6924 93 - 2x £0.40 A - 6936 54 - 4x £0.43 7 - 7426 24 - 2x £3.09 8 - 7427 16 - 2x £1.68 9 - 7429 47 - 4x £2.79 it totalled £27.28 i'll have to try and rescue the bracketty bits (6) cos they are almost £7 each Share this post Link to post Share on other sites
James_R 3 Posted June 23, 2008 Just start with the WD now, by the time you get round to it they'll com eoff eith yoru fingers Share this post Link to post Share on other sites
gerlewislewis 0 Posted June 24, 2008 "com eoff eith yoru fingers" thats easy for you to say! Share this post Link to post Share on other sites
