Rich_p 23 Posted June 12, 2008 I'm going to be removing my sunroof and plating it over. It currently has the vacuum set up which I will need to remove. What do I need to remove exactly and where from? Share this post Link to post Share on other sites
Baz 421 Posted June 12, 2008 If you remove the plastic trim surrounds all will become clear! But, there is some retaining nuts etc inside the car, basically it's easy once you start doing it, everything reveals itself! The vacuum side of it isn't an issue tbh. Share this post Link to post Share on other sites
Rich_p 23 Posted June 12, 2008 Thanks, I wasn't sure if there was anything connected to the engine that would need to be blanked off? Share this post Link to post Share on other sites
Ryan 99 Posted June 12, 2008 There is a vacuum reservoir under the slatted black panel under the windscreen (passenger side). It has a hose leading to the sunroof, and another connected to the engine somewhere (not sure where), which should be blocked off. Share this post Link to post Share on other sites
Baz 421 Posted June 12, 2008 Takes it vacuum from the same place the servo does, there's a little cylindrical jobby with a T piece near the Servo. Share this post Link to post Share on other sites
