Batfink
Straight Cut Final Drive
Batfink
I have a straight cut gearbox basically sitting around and I'm thinking it should go into a standard 1.6 gti I can use as a fun runaround.
Only thing is its got a standard final drive which means it will be quiet.
I'm thinking I should track down a 1.9 straight cut FD to give a great petrolhead noise.
Would it be a straight swap? Diff out - swap, diff in job?
Edited by Batfink
James_R
the output shaft would need swapping over too, and I didn't knwo 1.9 finals where straight cut, theones I've seen haven't been :)
If it is a straight cut box it will make enough of a racket as it is, no point going for a straight cut final drive unless you really want to piss your ears off. Sounds good for about the first 2 mins. After that it is just annoying. That is speaking from experience of driving cars with straight cut boxes about (minis).
They're not...
But, Batfink wants one. :D
Batfink
oh well it was a good idea for 30seconds!
James_R
On that note I'm sure Quaife would make you one, but at £500-600 a pop is it worth it, oh and straight cut finals are weaker than semi helix.
I'd have the gearclutster from that box :) rather nice
