Ethos
Central Locking Has A Mind Of It's Own...
Ethos
Hi guys,
So the central locking likes to unlock/lock itself randomly, sometimes about 10 times in a row (s*it myself the first time this happened!).
Any ideas, not too sure how to troubleshoot a problem like this. Although it does sound like the boot isn't properly shut, but when I try it- it's seated fine.
Ethos
Bump!
Ignore the "boot isn't shut properly" part.
Still happening but more rare than it was.
Any ideas, guessing a wire is shorting on something? :wacko:
Gentrix
I once had the same, but only after strong rain, or a wash.
found out, that the Doorloom was scrubbed through and was shorting some cables in the wet puddles.
andi
jimistdt
My battery is not the strongest and sometimes when it's strained and I try to start up I get this phonomenom. It doesn't do it all the time probably once a month, but thats what i have put mine down to.
Ethos
jimistdt, funny you should say this. I got this mostly when the battery used to drain with the 1.6 engine.
The alternator ring connector was in a v.bad state (I need a new power loom soon).
I thought it could be this so plopped the battery on charge, but within 2 minutes it was saying full charge... so not to sure it is that now.
Guess I should check cables + water then!! :wacko:
Rob Thomson
I asked the same question about a year ago. The concensus then was that one of the linkages or locks was a bit 'sticky' and that a good clean and/or lube would sort it out. I couldn't tell you if that concensus was correct as I've hardly used the car since.
Ethos
:excl:
Thanks mate, now where did I put that 3 in 1 oil...... :wacko:
jim205GTI
Could it be a dodgy fuse? :wacko: , not sure what else runs off the central locking fuse....
