dcc 855 Posted June 7, 2008 Fully Stripped down my engine. took it out and gave it a new head gasket and timing belt! only to find a brand new water pump had been fitted with a rather shiney edge to it :> all set up properly! (had a mechanic check the belt) only thing is I f***ED the lower rad pipe, the upper rad/thermostat pipe and a few other pipes >.< now then... a ) where can i get the pipes other than peugeot ( priced them so far @ £170 posted, any where cheaper?) b ) where in south wales could i get the engine steam cleaned? c ) where in south wales is there a dyno? Share this post Link to post Share on other sites
Fox 3 Posted June 7, 2008 Pipes are available from here - Auto5 I did the same when I removed the old engine from mine! As for the steam cleaning and dyno, yellow pages? Share this post Link to post Share on other sites
daza4 24 Posted June 7, 2008 Talk to Stew Baker on here for some Silicone hoses. They actually work out cheaper than original hoses form peugeot. or check out BBM, Baker Bushes and Mountings, They do advertise on Ebay aswell. If you tell them you saw them on the 205drivers they will also sort you out some discount! Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted June 7, 2008 http://www.bakerbm.com Share this post Link to post Share on other sites
