Quigs
Dimma Kit
Quigs
Hi all
I'll be fitting a dimma kit to my 205 in the next couple of weeks, was just wondering what would be the best thing to stick it on with,
Fibreglass, Sikoflex, i will be riveting it on as well.
Also the rear quater's, do the have to be modified??
was thinking i might have to make the arches bigger then modify/make the wheel arch to join the quater.
i got no problem in modifying the rear as i'm a panel beater.
any help would be most appreciated.
Cheers Quigs
Quigs
Any body got any ideas??
Quigs
toddydal
just use what youve said above really
craig f90
As youve said, but use the best materials you can get your hands on. Ive seen a so called $hit hot body shop do a dimma kit which was well, $hit. Sinkage or bad prep work around the joints and filler popping off the rivet heads. Just amazed me how the job took 8 months and looked poor.
I think your going to have to fill the rear arches with waterproof spray foam to put some rigidity into the composite panels. And maybe a splash guard.
I really doubt your gonna do a shoddy job being a enthusiast and a panel beater though. Are you going to keep us posted?
The Ex missus wants me to do one for her. :)
Quigs
The Ex missus wants me to do one for her. :P
yes mate will keep you all posted.
the arch,s are very rigid to start off any way so i will just put them on, will be making arch liner's to fit as well,
just tried the rear arch on now and only got to cut about 2 inch off, so not to bad.
i'll put up a few pics in a bit though.
Quigs
