sonofsam
Rad. Fan.
sonofsam
Do people, when fitting slimline fans usually put them on the N/S?
Would it matter swapping an OE fan to O/S?!
It would be further away from the fan switch in the rad though is my only thought why not?
Just hatching a plan :blush::o Ignore me if you like :wub:
tom_m
Just hatching a plan :wacko::D Ignore me if you like :blush:
i doubt it will make that much of a difference, to controlling temps.
James_R
Which ever side you fancy usually :wacko:
Mines tight on the passanger side cause there happened to me the most space there.
sonofsam
Cheers Lads! Moved mine to the drivers side as I needed to hoik my 'cooler up a bit as I must of ground out on one of the pipes :)
Made no difference to fan switching on/off or temps. although I have just fitted a new rad, so temps. are much better then
before with a leaky one!
