JR20516V 6 Posted June 4, 2008 As above. looking to rebuild my spare Tarox 4 pots with new seals etc. but dont know anybody that supplies them. Anybody help ? cheers Share this post Link to post Share on other sites
saveloy 8 Posted June 4, 2008 http://www.tarox.com/en/kontakt.php Got this from their website. Share this post Link to post Share on other sites
JR20516V 6 Posted June 5, 2008 Thanks for that Saveloy. Unfortunately that is the same one i looked up which reads " we do not have rebuild kits for our products....if you need it rebuilt then send them to Tarox themselves" A little expensive considering where i am. cheers for you input tho !! Share this post Link to post Share on other sites
saveloy 8 Posted June 6, 2008 Aaah, I should have been a little more observant. That's shocking though. Fancy not having re-build kits. That's ubsurd. If you have the piston sizes, perhaps you can source the rubber outer seals from another manufacturer? The inner seals will most likely be square seals. So, again, we just need the size. What a bunch of cocks. Really... Share this post Link to post Share on other sites
JR20516V 6 Posted June 7, 2008 Aaah, I should have been a little more observant. That's shocking though. Fancy not having re-build kits. That's ubsurd. If you have the piston sizes, perhaps you can source the rubber outer seals from another manufacturer? The inner seals will most likely be square seals. So, again, we just need the size. What a bunch of cocks. Really... piston diameter is 30.8mm and has 3 seals on every piston....unusual that they are all round seals. no square one in sight. Total of 8 pistons. Tarox Italy are starting to respond however the language barrier is a problem. I was hoping to get a supplier in UK for that reason. cheers Share this post Link to post Share on other sites
saveloy 8 Posted June 8, 2008 OK mate, can I assume that the2e are inner seals and there is no outer rubber boot dust seal? If so, finding the correct size may not be too big an obstacle. I need to shoot off now, but I will do some searching later today for you. Bye for now. Kyri Share this post Link to post Share on other sites
saveloy 8 Posted June 8, 2008 I have had a look around, but unfortunately I've failed to come up with anything. Good luck with the Italian. Share this post Link to post Share on other sites
