Gtiracer 0 Posted June 2, 2008 I need to connect the power wire from the ignition barrel from my ECU so it knows when to turn on and off. Which wire is this and what is the best way to connect it in as a 2 way wire if you get what i mean, because this wire will already be going somewhere and i will need to take the feed off it as well hope that makes sense. Cheers Share this post Link to post Share on other sites
welshpug 1,677 Posted June 2, 2008 the switched live usually just triggers a relay, power then goes from the relay to the ecu, coil, fuel pump injectors etc. Share this post Link to post Share on other sites
Gtiracer 0 Posted June 3, 2008 So which wire is the switched live then, is that the wire i need? Share this post Link to post Share on other sites
gti-si 0 Posted June 3, 2008 Im not sure I understand 100%, could you explain the problem a little more? As said, your switched live usually goes to a relay, which then feeds the injectors, coil and fuel pump. This can be done by using the red switched live (2a) that comes from the smaller brown multiplug under the dash. You shouldn't need to take a switched live from the actual ignition barrel. Share this post Link to post Share on other sites
Gtiracer 0 Posted June 3, 2008 ahh right, that makes more sense, thank you, I thought you had to take one direct from the ignition barrel, thank you Which multiplug is it, the smaller or bigger one? Cheers for your help Share this post Link to post Share on other sites
gti-si 0 Posted June 3, 2008 I think they vary sometimes, mine was on the smaller IIRC. Just have a look, it's a thick red, should be in with a much smaller yellow wire and it's numbered 2a. The ignition barrel wires go to the fusebox first I would imagine so I wouldn't recommend taking the feed from there Share this post Link to post Share on other sites
Gtiracer 0 Posted June 3, 2008 lol, no, not very experienced at this wiring lark i must admit but thanks very much for you help Share this post Link to post Share on other sites
