Ormy
The Dreaded Rot!
Ormy
The rot has finally started to kick in, should have tackled it straight away but just haven't had the time or the means. Can anyone suggest what I can do about this? It's in an awkward place and I'm not sure at all.
Thank you!
Tommer
eeeek not good, how bad is it around that rust spot, does it feel like its spread? I reckon cutting out the rot and welding a new bit in :angry: not fun
matty_gti
Doesnt look to bad but you wont know untill you remove the paint etc n grind it back, i doubt you'll need to cut that out.
