Project205 0 Posted May 27, 2008 Hi All, I have had the car apart for a little while but now putting it back together. I cannot for the life of me remember where to clip the grey plastic plug for the radiator. Could someone describe where it should be mounted? A picture would be fab! Many thanks. Share this post Link to post Share on other sites
welshpug 1,636 Posted May 27, 2008 the grey plastic plug as in the 2 pin main feed? either on the chassis leg/inner wing, or on later car on the underside of the panel behind the headlamp. Share this post Link to post Share on other sites
Project205 0 Posted May 28, 2008 Yes this is the plug I am referring to. Ok, mine is a later car so I will check to see which hole it should clip into. Many thanks. Share this post Link to post Share on other sites
