Pt2051900tdic
Gaz Coilovers With Eccentric Top Mounts
Pt2051900tdic
Hi
I have buy a 205 and it cames with a full set of gaz GHA coilover suspension.
Now i want to upgrade the top mounts for a eccentric tops, what i need to change it?
Where i can buy the top spring pan for the gaz?
I can take a pictures of the suspension if the experts want for give an opinion.
Regards
Nelson Viegas
MerlinGTI
Gaz sell eccentric top mounts for the GHA's, they are all you need (direct replacement for existing top mounts) but you may run into problems with not having enough thread on the coilover to do up the center nut. Ask gaz. Reason being when I bought my GHA's I had to specify 'modify for eccentric top mounts'.
