16v205 9 Posted May 25, 2008 Hi Has anyone got the measurements of the square drive section on the 205 steering rack? I’ve had a look at my spares but there all spline type. I need the dimensions for a little project im looking at Cheers Rich Share this post Link to post Share on other sites
16v205 9 Posted May 28, 2008 Anyone got a pic or anything? Share this post Link to post Share on other sites
Pug_Power_Dave 0 Posted May 28, 2008 Yea i've got one apart at the min, i'll get some measurements and pics tomoz if i get a chance, feel free to give me a pm reminder Share this post Link to post Share on other sites
Pug_Power_Dave 0 Posted May 29, 2008 Heya there, right did some measureing for you, the shaft sticking out the rack is 55mm long, There is a rounded section, then the square section then a few more mm of rounded section at the top (pic to show) The 1st rounded section goes 12.5mm up the shaft For the square section it's two flat sides oposite each other which are 15mm apart, the 3rd side is rounded and the 4th is rounded with a small indent for the tightening bolt. Hope this helps, it's just a quick phone pic, if you need a better detailed one give me a shout. Share this post Link to post Share on other sites
16v205 9 Posted May 29, 2008 Thanks very much for that, ill scribble the measurements down and check tomorrow. Rich Share this post Link to post Share on other sites
welshpug 1,666 Posted May 29, 2008 so its essentially round with an indent for the bolt to stop it spinning? Share this post Link to post Share on other sites
Jrod 7 Posted May 29, 2008 so its essentially round with an indent for the bolt to stop it spinning? Not really, 2 of the flats stop it turning as they locate into the column and the other flat is where the bolt goes. Share this post Link to post Share on other sites
welshpug 1,666 Posted May 29, 2008 oh ok, just trying to understand the difference and how it works, mine is splined see Share this post Link to post Share on other sites
Jrod 7 Posted May 29, 2008 IMO the square is the better design. With the spline I always had to undo the lower column to slide it onto the rack. With the square it just pushes on from behind and the bolt holds it there. Not that you should have to change racks often enough to worry but ya know, I seem to! Share this post Link to post Share on other sites
Pug_Power_Dave 0 Posted May 30, 2008 No worries Rich! Yea I prefer the square drive rack to! easy to change from spines to square aswell, just need to change the lower part of the colum aswell to get the right fitting! but exactly the same for both into the top part of the colum! Share this post Link to post Share on other sites
