NeilGTi85 5 Posted May 25, 2008 Hello All, Managed to snap my clutch cable today, called the AA and the guy put a tempory cable on. I have a 2L 405 MI16 engine in my 205, any help would be great Cheers Neil Share this post Link to post Share on other sites
welshpug 1,666 Posted May 25, 2008 doesn't matter which engine is fitted, what gearbox and age of car is it? Share this post Link to post Share on other sites
Arahan 4 Posted May 25, 2008 I've only changed BE3 cables, with reverse under 5th, and its only a few steps! I did it by attatching it to the back of the clutch pedal 1st, then routed it round to the gearbox mount, then finally into the arm! Then just adjust it by tightening or loosening the nut at the end for the pedal height! Share this post Link to post Share on other sites
Phil H 16 Posted May 25, 2008 ...it's a pig to get the gommet into the hole under the master cylinder, so connect it up to both ends and press the pedal down and through she pops. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 25, 2008 what gearbox and age of car is it? Not that difficult to work out, especially when you have pretty much the same car. Its a 2.0l Mi 405 so 93 onwards which should have a Be3 gearbox fitted. Changing a 405 Be3 clutch cable isn't much different to a Be3 one on a 205, your working on your head in the drivers footwell to unclip the remains & clip the new cable end onto the pedal & then the gearbox end is easy once you've got access to it by removing the associated airbox pipework so you can see the gearbox lever where the cable hooks into & adjusts. Graham. Share this post Link to post Share on other sites
