boldy205 75 Posted May 25, 2008 Hi i hae just ordered a mocal Air-Oil cooler and have just thought about the clearance between rad and oil filter. Will it be a bit tight Once the sandwitch plate is on? Has anyone else used this setup and had a problem? Can a shorter filter be used? Thanks Matt Share this post Link to post Share on other sites
tidypug 5 2 Cars Posted May 25, 2008 yes it is a tight fit, i have used the oil flter from a renault 19 16v i think. They are very short and solve the clearance isssue. Share this post Link to post Share on other sites
smighall 1 Posted May 25, 2008 Another for the renaullt filter here Share this post Link to post Share on other sites
Spiky 37 Posted May 25, 2008 mine had the renault filter fitted too, gives much more room i have a mocal too Share this post Link to post Share on other sites
tom_m 0 Posted May 25, 2008 i didn't have a problem with space on mine, the mocal is no bigger than the OE sandwich plate Share this post Link to post Share on other sites
Miles 331 1 Cars Posted May 25, 2008 The Renault filter is fine or you can use the remote filter take off plate as fitted to all late model 1.9's Share this post Link to post Share on other sites
boldy205 75 Posted May 26, 2008 Thats just what i wanted to hear thanks! recon i will go for the 19 filter! Once again problem solved!! thanks. Matt. Share this post Link to post Share on other sites
