ccgoose 0 Posted May 24, 2008 well i only drive about 5 miles to work and back a day, most of which is through traffic at about 20mph (thanks to the school run and copious numbers of 4x4's) Last night returning from the gf's house, it's got the to stage where you can depress the pedal so far then the last bit sort of clicks down if that makes sense? Had a PM this morning with an offer of a phase 1 gearbox which i'd like to get but if the clutch is on the way out, i'l need tog et that first Share this post Link to post Share on other sites
Tommer 0 Posted May 26, 2008 have you had a look under the bonnet, make sure nothing is fouling (catching/rubbing) on the clutch cable where it joins the engine / gearbox? Share this post Link to post Share on other sites
