dani959 0 Posted May 23, 2008 Right then, I decided to go with the proper injection route (probably on my way to a Mi) and just ordered a megasquirt. Setup will be: MS1 chip on a v3 board; Mi16 flywheel (60-2); Megasquirt-n-spark, running wasted spark on a 405 or 103 coil pack; 405 idle valve; Narrowband lambda sensor. Anyone has some fuel maps for an 8 valve that can help me get started? Cheers all, Daniel Share this post Link to post Share on other sites
madspikes 41 1 Cars Posted May 27, 2008 To tune it yourself your really going to need a wideband lambda sensor as a narrowband sensor will only say too ritch or too lean. A wideband will say how much too ritch or lean, which will make it so much easier to tune. When I was playing around with the MS on my standard 1.9 a few years ago I found the base injection map created by Megatune was good enough to start and get the car to idle. I never really progressed my standard map any further before I pulled it all apart for the supercharger install. Mad. Share this post Link to post Share on other sites
