TaffyTim
Top Engine Mount
TaffyTim
Hi
On a trackday yesterday 2 of my nuts came off from the mount. Looking at past pics of the engine bay they have been loose for a while :D
When tightening them back up 2 of the studs were spinning too so i better replace them too
Is there much difference in price between Peugeot ones and gsf ones?
Does anyone have the part no's to hand?
Heres a pic just to confirm what im on about:
ta
Tim
2-Pugs
Not sure you'd need to replace the stud, just loctite them back into the block.
The nuts aren't nylock, but maybe you should fit some if you're having trouble with them loosening?
C_W
I used to have trouble with those coming loose too, never sure why (I was running standard engine mounts too). I used to have to tighten them so much that the washers would split!
TaffyTim
ok thats reassuring to know that im not the only one :D
TaffyTim
True, but if the bits are only a few quid then i'd rather do it properly and replace them.
Most of the bits that have been replaced on the car were of low quality, so every time something goes wrong I want to replace it with something that i can trust and not worry about.
The studs should just tighten back up into the mount, a drop of loctite on them wouldn't go a miss though.
A couple of M10 (iirc) nyloc nuts & wshers should help prevent them coming loose again.
You should be able to get these from any decent hardware store rather than paying silly money for the same bits from peugeot but if you want to order new studs as well the part # is 6932.38.
TaffyTim
Thanks very much
