reuben205
Roof Plate To Replace Sunroof,where From?
reuben205
Where can i get one of these?Theres no group buys but i am very interested in getting one.does anyone have the dimensions etc or where to buy one?
thanks
projectpug
If you have a look in the group buy section theres one being looked into :D
reuben205
yeh saw that but seems nothings happening with it.what material is used?is it rolled and cut sheet steel?
Henry 1.9GTi
just measure the hole, then buy a sheet of 1.5mm ali from a local engineering shop / metal works or where ever you can get it. Then offer it up and cut the curve with a jig saw, file it down for the final finish, as its ali its very easy to file down to shape.
I could possibly arrange a group buy of sheet steel in roughly the right size for a good price but you would need to finish it yourself.
casnell
I've got a 1.5mm Alloy one for sale, but postage may be a bit much...
I'd be open to offers...
AdamP
I've used 1.6mm ali for mine. I couldn't think of any reason why you would use steel instead!
I use galvanised steel sheet because there are issues with dissimilar metals corroding in the long term.
