jtek 0 Posted May 19, 2008 Hi, My housemate is rebuilding an a 1.9 MI that had a bottom end knock. After getting all of the rod caps off we found that the rod bearing on the 3rd piston from the cambelt end (not sure which way they number these) was goosed, along with what we expect to be the central main bearing. This is already proving a massive problem to get off as it is clamped in position at each end by the block itself. We have tried everything to remove it and it just won't budge. Also we have unseated 2 of the liners, i am guessing these need new seal rings and to be seated at the correct depth? Many Thanks Share this post Link to post Share on other sites
pee vee 1 Posted May 19, 2008 there is a bolt either side of the engine that holds that bearing cap in place mate! have a look, its about a 13mm if i remember rightly. on the back, and the knock sensor mounts on the front one.. Share this post Link to post Share on other sites
jtek 0 Posted May 19, 2008 Oh S*** the bed that makes us look stupid haha, however watching my housemate running around the house screaming when we got it out put a smile back on my face. Muchos Gracias, the crank came out with no trouble then. Share this post Link to post Share on other sites
smokey 0 Posted May 20, 2008 Oh S*** the bed that makes us look stupid haha, however watching my housemate running around the house screaming when we got it out put a smile back on my face. Muchos Gracias, the crank came out with no trouble then. Nah dont worry mate. I did the same and asked the same quest a few months ago. You'll find quite a few of us fell over at that point! Share this post Link to post Share on other sites
taylorspug 7 Posted May 20, 2008 Yes if you have unseated the liners best bet is to replace the seals and clean up the seats. Or get some good seconhand liners if yours are badly lipped on the thrust side (ie knackered). Share this post Link to post Share on other sites
mechsmurf 0 Posted May 20, 2008 sorry to hijack but do the liners have a certain way round they go i read in haynes that there should be marks but i cant see any Share this post Link to post Share on other sites
