Peetypug
Gti6 Oil Pressure Sensor
Peetypug
right
i've started to sort the engine out ready to put it in the car
but, when i've come to fit the pressure sensor i cant find anywhere to put it
all the available holes are occupied by other sensors
which can i remove and replace with the sensor?
is this the oil level sensor? can i remove this and swap one of the above ones into it then put the pressure sensor where that was?
the only vacant one is under the exhaust manifold :angry:
its from a 1998 phase 2 gti6
Edited by sorrentopete
Matt Holley
right
On mine I kept this one for the pressure lightth_oilpressuresensorlocation002.jpg
And I swapped this one for the pressure gauge
Im not sure why they have 2 oil pressure warning senders in the block as the first one on mine was not connected to the loom at all, mines the vts engine though
taylorspug
Ive got mine fitted in place of the right hand sender on the front of the block (1st picture).
tom_m
you can swap it for either one of these two
Peetypug
thanks :angry:
given up for the day now, just enjoying a pint of tramp juice (cider) ;)
Spiky
i run a 205 pressure sender on the left of the engine and no low warning
rossi's will run a s16 pressure sender on the left and low (vts) pressure sender on the right
