Peetypug 5 Posted May 18, 2008 (edited) right i've started to sort the engine out ready to put it in the car but, when i've come to fit the pressure sensor i cant find anywhere to put it all the available holes are occupied by other sensors which can i remove and replace with the sensor? is this the oil level sensor? can i remove this and swap one of the above ones into it then put the pressure sensor where that was? the only vacant one is under the exhaust manifold its from a 1998 phase 2 gti6 Edited May 18, 2008 by sorrentopete Share this post Link to post Share on other sites
Matt Holley 11 Posted May 18, 2008 right i've started to sort the engine out ready to put it in the car but, when i've come to fit the pressure sensor i cant find anywhere to put it all the available holes are occupied by other sensors which can i remove and replace with the sensor? is this the oil level sensor? can i remove this and swap one of the above ones into it then put the pressure sensor where that was? the only vacant one is under the exhaust manifold its from a 1998 phase 2 gti6 On mine I kept this one for the pressure light And I swapped this one for the pressure gauge Im not sure why they have 2 oil pressure warning senders in the block as the first one on mine was not connected to the loom at all, mines the vts engine though Share this post Link to post Share on other sites
taylorspug 7 Posted May 18, 2008 Ive got mine fitted in place of the right hand sender on the front of the block (1st picture). Share this post Link to post Share on other sites
tom_m 0 Posted May 18, 2008 you can swap it for either one of these two Share this post Link to post Share on other sites
Peetypug 5 Posted May 18, 2008 thanks given up for the day now, just enjoying a pint of tramp juice (cider) Share this post Link to post Share on other sites
Spiky 37 Posted May 18, 2008 i run a 205 pressure sender on the left of the engine and no low warning rossi's will run a s16 pressure sender on the left and low (vts) pressure sender on the right Share this post Link to post Share on other sites
