dan1120 0 Posted May 13, 2008 right here gose,got r1 bike carbs on my 1.9 8v,got the injectors un pluged, plug to the airflow meter unpluged,runs fine my bros got the same set up on his williams clio,but hes got his thtottle pos sensor and inlet manifold temp sensor pluged in,do i need these pluged in on mine? do pugs have a manifold sensor?or will it make no difference on mine,thanks Share this post Link to post Share on other sites
dan1120 0 Posted May 14, 2008 anybody??????????????????????? Share this post Link to post Share on other sites
welshpug 1,682 Posted May 14, 2008 is your brother using the original ecu to run the spark? Share this post Link to post Share on other sites
dan1120 0 Posted May 14, 2008 is your brother using the original ecu to run the spark? yes he is Share this post Link to post Share on other sites
jackherer 543 Posted June 12, 2008 You definitely don't need them connected, your ECU isn't doing anything as it only controls injection, the ignition advance on 205 GTIs is controlled by the distributor. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 12, 2008 is your brother using the original ecu to run the spark? Yes but the ecu on a Clio Wiliams (Siemans MPI) is a better design & has a proper TPS along with CAS, IAT, VSS, Lambda & knock sensors so its a world of difference to the Jetronic fitted to a 205. This system might even be possible to remap like the MP3.1 & MM8P's are. Graham. Share this post Link to post Share on other sites
dan1120 0 Posted June 12, 2008 thanks for the replys so i can unplug my ecu now. Share this post Link to post Share on other sites
