gti-si
Closing Stages Of Gti-6 Conversion
Spiky
fuel prime shouldn't be priming all the time, only a few seconds when the ignition is on,
if it's priming all the time you have a constant live.
you can run the car with no lambda
i got roughtly the same issue, rossi's car wont prime, yet i do have a switched live to the ignition realy..lol DOH
gti-si
Hmm, not quite sure what it could be then, as it's wired up right from what I can work out, ive got the permanent live to the ecu, ive got the switched live to Pin 14 and I have the output ofr the fuel pump from the double relay connected to the fuel pump wire 76. On Rossi's car, which wire are you using to power the fuel pump?
I think this might be a small problem compared to what I dread/. The engine turns over so easily, it still turns about for about a second after the started motor is dropped and sounds like turning a conveyor belt not a bloody engine. I just cant see why it would have so little compression to sound like this without a giant hole somewhere?
Spiky
large red wire 1200
are the plugs in ok?
does sound like it's turning over too quick.
what it a know running engine?
