oilman
Oil Advice And Recommendations Here
oilman
I get asked many questions about oil so I thought a thread here for all oil related questions would be a good idea and build into a FAQ or reference point for others.
So, put your oil questions here but please give the following information if you would like a recommendation:
Make
Model
Year
Engine size/type
Any mods
Type of use (road/track)
Additional info (max oil temps, current oil used)
What do you want a recommendation for? Engine, Gearbox etc?
I hope this will help and become a useful thread
Regards
Guy
NeilGTi85
Hello Oilman,
I've got a ('L' reg 95) 2L 405 Mi16 block (80K) in my 205, I'm currently using Castrol Magnatex 10w40. It seem'd to be fine when it was winter but as summer is approaching and the temp gauge is rising a little when stuck in traffic I'm a little concerned.
Also, since reading alot of post's about oil surge's on 205's....i did a test run round some tight bends with some speed and noticed the drop on my guage (My pump and sump is standard)
Is there an oil which would be better suited to the warm weather and also to protect the engine abit more when/if it surge's?
My 205 is pretty much standard except the usual mods and is a road only car apart from afew sprints etc....but I do like the old country lane :rolleyes:
Neil
Ryan
I'm currently using generic 10W40 semi-synth in my 205 Mi16. It's used for a lot of short journeys though. Would I be better off switching to a different grade for better cold-start protection?
jord294
hello oilman
i am at present, fully rebuilding an engine for my 205 gti
is there a certain oil i should use on a, basically new engine?
it's the 1.9 xu9
thanks
swordfish210
Hi, as per your original post:
Peugoet
205
1992
1360cc TU3-A engine
284 cam with 11.4mm lift. Ported and gas flowed head, rebuilt but i used the original bearings, rings liners ect and i'm running bike carbs
Used as a daily driver and on track.
I'm using Castrol Magnatec 10w/40 at the moment and the oil runs at about 80 on the road and 100 on track
Engine and Gearbox please.
Thanks. Mark
Rom
Hi
Ive got the following
89 205 Gti, Rebuilt 1.9 Mi16.
No major engine work, bar balancing etc
Totally road use, though id like that to change :D
Ive been using Mobil 1 fully syn 0w 40. But have swapped to (what i think is) Castrol Magnatec 10w 40w (Its repackaged for Toyota, and i liberate it! Ill try and confirm) As ive been told that an engine of my design doesnt have good enough tolerances to use 0w 40 fully syn. IE scraper rings wont clear oil well enough etc,even if it is rebuilt. As it wasnt designed for that kind of oil.
It runs fine on the fully syn,im just worried ill do more harm than good.
As for gear oil, ive been using the stuff we put in Toyotas, fully syn 75 90 i thikn it is. Again, id have to confirm branding as its repackaged.
Many Thanks
Anulfo
surely the 1.9gti 8valve is best with a good quality 10w/40 semi synthetic???Thats what use in my sprint car and always have.
craig f90
hello guy,
my engine is:
peugeot 406 sri
96 'p'
2.0 turbo petrol
xu10 cte
Its a road car.
Thankyou. :)
Edited by craig f90
swordfish210
Peugoet
205
1992
1360cc TU3-A engine
Thanks. Mark
Thought i'd better add that it's covered 152,000 miles if that makes any difference to you and the gearbox has covered about 60,000
DamirGTI
Hello !
Peugeot
205 GTI
1987
XU9JA D6B 1905ccm
Engine is modified and rebuilt last year - gas flowed head , compression ratio 11.1 (CR raised with different set of pistons) , 405 SRi gearbox etc.
Daily driver (road car)
Oil temp - average 110C , maxi 130C
Im interested in engine oil recommendation :) I've been using 10w-40 multigrade oil in the past (Total or Shell 10w-40)
Thanks ! :(
Damir
Edited by DamirGTI
ANDYMISIXTEEN
Peugoet
205
1991
1.9 Mi16
Piper camswith, Head work, 45 Carbs, its been rebuilt and needs running in.
The 1.6 Be3 gearbox has also been rebuilt.
Used as a daily drive.
I need to know both Engine and Gearbox please.
swordfish210
did anyone hear anything more on this? :D
NeilGTi85
Nope ;):D:huh:
CaptainK
They've probably been busy organising and going to Japfest over the weekend. I got my oil from them there as I had my FTO go on the track there at Castle Coombe. :D
swordfish210
slightly off topic but what did you think of Castle Combe, how does it compare to other curcuits you may have been on?
CaptainK
I really enjoyed Castle Coombe. Nice mix of slight cornered main straight foot to floor action and some wiggly action around the back part of the course. Didn't like the chicane where the exit corner edge has a dip on the inside "red and white" marked track section. Thats the racing line I believe, but it also means the dip causes you to lose traction for a split second on your passenger side wheel as you go over it.
Can't compare it to any other tracks as previously I've only done one lap of the Nurburgring and that was done fairly easy as I needed my car to be working for the rest of the week as we (FTO owners club) were touring around europe.
swordfish210
Imagine how fast it would have been if the chicanes wern't there though like it used to be :blush:
CaptainK
  swordfish210 said:
Imagine how fast it would have been if the chicanes wern't there though like it used to be ;)
I love the corners and accelerating out of them. Tis the only way to catch up / overtake some people when you are in a track session with cars that are almost identical. ;)
oilman
  NeilGTi85 said:
Hello Oilman,
My 205 is pretty much standard except the usual mods and is a road only car apart from afew sprints etc....but I do like the old country lane :P
Neil
Neil,
Sorry for the late reply, its seems I did not have notification of the thread... All sorted now!
Anyway for the MI16 a good 5w-40 synthetic is ideal and much much better then the mineral Castrol. Synthetics are better dissapating heat so it will keep the engine slightly cooler.
Have a look at these 5w-40 oils, if you want the best then look at the ester based Silkolene pro S and the Motul 300v.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Guy.
oilman
Yes you would mate, have a look at a 5w-40 synthetic.
Guy.
oilman
  jord294 said:
hello oilman
it's the 1.9 xu9
thanks
If the engine needs running in then you will need a mineral based oil to do so, a good 10w-40 semi is ideal.
Once run in if you want better quality then look at 5w-40 synthetic.
Guy.
jimistdt
Hello Oilman,
205 STDT 1.8 TD 1769cc (1994)
Used on the road.
Currently I am using a mineral 15w-40
Is this a good match?
Thanks Jimi.
oilman
Peugoet
205
1992
1360cc TU3-A engine
Thanks. Mark
Mark,
The Magantec is fine for normal road use but is really not up to the job of track work.
I would look at a 5w-40 synthetic, ideal for fast road and track.
Guy.
oilman
  Rom said:
Hi
Totally road use, though id like that to change :P
Many Thanks
Hi,
The Mobil 1 0w-40 is a good quality synthetic, much much better then the Mangatec. The 0w-40 is not too thin. When nhot a SAE40 is an SAE40 so MAgnatec and Mobil 1 0w-40 are both the same viscosity when hot.
The Toyota 75w-90 is fine, I assume you can get it cheap or something?
Guy.
oilman
  craig f90 said:
hello guy,
my engine is:
peugeot 406 sri
96 'p'
2.0 turbo petrol
xu10 cte
Its a road car.
Thankyou. :P
Is it modified?
Guy.
