mechsmurf
Suspension Strut Top
mechsmurf
is there supposed to be anything inbetween the top cover on the suspension strut and the chassis ie a rubber
chris1986
there is like a round rubber ring yes. then under that is the bearing
mechsmurf
are these the rubbers that you can get off ebay or where could i get replacements many thanks
mechsmurf
cheers
Rich_p
Can these be replaced just by undoing the 3 top mounting bolts and dropping the shock once the car is jacked up or is it a shock off the car job?
KRISKARRERA
But there isn't anything between the top of the strut and the bodywork.
Rich_p
I haven't taken a 205/309 apart yet so wouldn't know! I'm assuming it's shocks off then?
Edited by Rich_p
KRISKARRERA
I assume you were asking if there is anything between the bodywork and that top bit that is visible now?
GLPoomobile
That's what I assumed too Kris.
The metal top plate that protrudes through the strut turret has nothing between it and the shell. The bush mentioned above goes between the metal top plate and the rest of the top mount assembly.
